harleyrkc
Welding:
5 posts in this topic
I have a series of shapes forming the overall shape im looking for and welding the shapes themselves works just fine.  But to achieve the overall appearance that I'm looking for I used a white object between several layers.  When I weld them it ignores the white and brings all the objects to the front.  Is there a way to weld all but that one object?
You are going to have better luck with specific help if you can manage some screen shots to show what you are talking about. Generally speaking you should elect only the items you want to weld when performing that operation. The order of the objects in the stack may change covering up the white so you might have to move it back to the top or at least on top of the object you just created.
1 person likes this
if you have multiple layers with the white some where in the middle you're probably going to have to do some combination of welding and cutting. When you weld something you are taking two objects from different layers and combining them into a new layer. So if you had a white piece between them that will no longer be possible, the white will now be on top or below the new welded image.
Screen shots would help a lot with more advice.
1 person likes this
Can you please elaborate more or be more specific?
نویا سیستم
Guest
Reply to this topic...
×   You have pasted content with formatting.   Remove formatting
  Only 75 emoticons maximum are allowed.
Loading...
