decca591 0 Posted February 14, 2017 (edited) Hi Guys I have a plain heat press that does not heat up. There is power to the press, the countdown lights up and works, but no lights on the temp controller and no heat. Pulled and waggled everything I can see and feel - all seems connected ok. Transformer doesn't light up, but if I take it off, put 9 volts thru it then it does light up a bulb that I connected to it, don't know if this helps, but not much else I can check - any ideas as where I should poke and prod next ? Decca Just thought I'd add a couple of pics, the two images show my controller on the left, and the one sent as a replacement on the right - questions is, is it possible that the controller on the right can be wired given the configurment of the wiring on mine ! The other difference is that the replacement is about a third deeper than mine, though height and width are same and they both fit same slot ! Decca Edited February 16, 2017 by decca591 Adding images Share this post Link to post Share on other sites
