signman911
Can someone tell me what is going on
Creation ct630 one picture is what i see before i cut and the other is when cutting
and it cuts the lines across the letters
In the first picture, the dashed lines is just where the blade is moving to. Only the blue or red solid line is where it will actually cut.
Now if you are saying that the blade is cutter on the dashed lines as well, then maybe you pressure settings are too high. Try lower the pressure to maybe 80 to 100 and try the cut again.
Hope that helps
Thanks i cut 4 of them  i only use 80 pressure it doesn't cut all the lines that i see but
some of them enough to ruin a couple letters from each one
try adjusting the blade to where less sticks out. The only other thing I can think of is that the blade isn't lifting as it should,which could be due to static electricity.
