TamaraVL 0 Posted January 19, 2017 Hola a todos: Tengo un problema con el mi MH 721 MK 2. El asunto es que siempre hay un corte que no me cierra en las esquinas, adjunto un gráfico para explciarme bien. Mi equipo esta instalado via USB y no tengo puerto serie en mi PC. Además para cortar utlizo tanto Corel como Ilustrator, en los dos me sucede lo mismo. Agradecería cualquier ayuda. Gracias por adelantado! Hello: I have a problem with my MH 721 MK 2. The thing is that there is always a cut that does not close in the corners, I attach an image to explain myself well. My cutter is installed by USB and I do not have serial port on my PC. I' ve been traying to cut using Corel and Illustrator, the same thing happens to me in both cases. I would appreciate any help. Thank you! TamaraVL Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted January 19, 2017 "I' ve been traying to cut using Corel and Illustrator, " You need a cutting software, Corel and Illustrator are not cutting software, they are design software. With those 2 programs, you do not have any options like blade offset or over cut to correct this problem. Those features are in a cutting software.. You could try the FREE unlimited trial of Signblazer design and cutting software. Or if I am reading this incorrectly, which cutting software are you using? Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 19, 2017 What is your overcut set to? Try increasing that a little. Share this post Link to post Share on other sites
