shadybiz11 1 Posted January 14, 2017 I have a titan, and I just purchased VinylMaster Cut 4.0. I design in CorelDraw, so the guy at US cutter said that I could just use the basic Vinyl Pro. On Friday he helped me select the correct plotter for the software which he selected, (USCutter MH-871). When I try to cut, I get the message, "The USB device is not connected . Click "detect" to find the device." The Titan shows up on my computer as being connected as a an unspecified object. Saga cutter plotter. How do I get it to cut? Do I need drivers? Anyone? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 14, 2017 there are specific drivers he should have given you a link to for the titan cutter. there is a special edition of vinylmaster for the titan - I am pretty sure the mh drivers will not work with taht cutter. which model of titan did you purchase from uscutter? Share this post Link to post Share on other sites
shadybiz11 1 Posted January 14, 2017 I bought it used. It is a titan 1 I believe. The support tech said that the MH-871 would work. But, I don't think it is. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 14, 2017 I don't either , somewhere I have a link for the titan2 (that has a servo motor) drivers but not the titan 1 that has a stepper motor Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 14, 2017 if your cutting software has the set up for the saga cutters try that Share this post Link to post Share on other sites
shadybiz11 1 Posted January 14, 2017 I got it working. Thanks for your ideas! 1 Share this post Link to post Share on other sites
