pareecustoms 2 Posted January 11, 2017 I have a us cutter MH-871 34". Been having this same issue since it came out the box. Cutter wont cut the complete design, completes the outline (most of the time) but i have to use my exacto knife to to make sure it weeds correctly. Ive played with the settings im cutting at low speed alot of pressure still missing way to much of my designs which arent very detailed. cuts perfectly fine with sign vinyl but not with heat transfer materials. before you respond...new blades, grounded twice, using scal3, usb to cpu, i attached a photo of my latest issue and as you can see the design cuts perfectly on half the other half isnt even visible enough for me to go behind it. Please Help. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 11, 2017 can I say add to the overcut - pretty sure scalp has the overcut feature. stepper motor cutters are infamous for leaving that little tag - servos tend not to do that but the overcut will mask that 2 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 i have sclaps4pro running on a titan2 and havent had that issue with cut....What is your overcut set to? Mine is at 1.00mm and blade offset is .30mm .these numbers are default settings and i have never changed them...let me know..... 1 Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 never chaged these settings Overcut 3.5 blade offset is .30mm Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 mark offset .64 mark size 2.00 cm mark thickness .25 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 1 minute ago, pareecustoms said: mark offset .64 mark size 2.00 cm mark thickness .25 this is in scalps? i will check my scalps3 version 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 Yours are the same as mine...Jog Distance is .05 normal.......... .30 fast...... x and y resolution is 1.000............ Blade offset is .30mm over cut is 1.00 ( make sure it is check marked next to it) Baud is 38400.............. mark type is 3(TL,TR,BR) can you send me the file or make sure your image is joined or complete as one.....and make sure the software is registered to use otherwise it will not work either.. 1 Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 yep scalp3....everything matches yours except my overcut is 3.5 Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 i checked the little box is marked but my baud is at 4800 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 Just now, pareecustoms said: yep scalp3....everything matches yours except my overcut is 3.5 take note of your settings and change it... do a simple test cut with both settings and see what it does.. Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 about to try this now well update asap thanks for the help. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 11, 2017 keep in mind you two are comparing a servo titan2 to a course stepper mh series so setting will not be the same 3 Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 Do you have any advice on my issue by any chance? Dakotagrafx Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 10 minutes ago, Dakotagrafx said: keep in mind you two are comparing a servo titan2 to a course stepper mh series so setting will not be the same Very true....could their possibly a image issue? or are those cutters just that way sometimes. Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 8 minutes ago, Primal Decals said: Very true....could their possibly a image issue? or are those cutters just that way sometimes. i converted my image from psd to svg...everything is grouped together i cut lines are showing in preview properly. Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 11, 2017 From the image, and your description it sounds like you have two. 1. From the image it looks like it's cutting ok on the bottom, but not towards the middle/top. That could be a cutting strip problem. Is the strip worn/flattened down more in one place than the other? 2. From the image and your description, your cuts are not actually finishing. A small gap can be expected and the blade offset and over cut advice given above will help with that. But in the case of the K from your image, it's missing a large portion of the actual design. That seems like a software problem more so than hardware. If you could post the file you're working with we can take a look and let you know if there is anything wrong with it. 1 Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 15 hours ago, Primal Decals said: take note of your settings and change it... do a simple test cut with both settings and see what it does.. bro you saved my life and my money hahahaha thanks so much. tried these settings last night and made 40 shirts lol havent been to sleep yet. thanks man im in debt to you, 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 awesome ...Glad i could help..so what all did you change ? Share this post Link to post Share on other sites
pareecustoms 2 Posted January 11, 2017 3 minutes ago, Primal Decals said: awesome ...Glad i could help..so what all did you change ? i changed the overcut to 1.00 and every cut has come out perfect since. 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 11, 2017 cool..... Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 11, 2017 3 hours ago, pareecustoms said: i changed the overcut to 1.00 and every cut has come out perfect since. lol - covered in 2nd line 20 hrs ago 3 Share this post Link to post Share on other sites
