bethann 4 Posted December 1, 2016 I have a Graphtec ce6000 and I am trying some new things to me but probably very basic to you. I chose a clip art of the state of North Carolina. I would like state to be solid, but when I choose any of the trace options, it just leaves an outline of the state. I have attached pictures. Any suggestions Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 1, 2016 What software are you running? Share this post Link to post Share on other sites
bethann 4 Posted December 1, 2016 The graphtec software that came with the machine. It is called Graphtec Studio. Is there inexpensive software that I can purchase that is better? Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 1, 2016 There are a lot of options. I have a friend who has Graphtec Studio but I have never used it. I think you probably have the freebie version which is lacking a lot of options. Not knowing the software I would venture a guess and tell you to try and select the inner line and delete it. You are right there should be a way to trace for a solid line. You could also just manually draw the line around the outer edge. Auto tracing rarely gives a good result. Share this post Link to post Share on other sites
darcshadow 1,625 Posted December 1, 2016 Learning to trace is a great thing, but in this case, if you do a search on the forums you'll find all 50 states already in a vector file. Most states also have a Wikipedia page with a vector drawing as well. 3 Share this post Link to post Share on other sites
Primal Decals 621 Posted December 1, 2016 here you go.. in svg format 50 states.zip Share this post Link to post Share on other sites
mb20music 760 Posted December 1, 2016 Try Inkscape... https://inkscape.org/en/ Share this post Link to post Share on other sites
bethann 4 Posted December 5, 2016 On 12/1/2016 at 8:57 AM, darcshadow said: Learning to trace is a great thing, but in this case, if you do a search on the forums you'll find all 50 states already in a vector file. Most states also have a Wikipedia page with a vector drawing as well. On 12/1/2016 at 2:32 PM, Primal Decals said: here you go.. in svg format 50 states.zip Thank you all so much for your help. I appreciate you taking the time to teach me!!! Share this post Link to post Share on other sites
PatrickR 37 Posted December 6, 2016 On 12/1/2016 at 4:17 AM, bethann said: I have a Graphtec ce6000 and I am trying some new things to me but probably very basic to you. I chose a clip art of the state of North Carolina. I would like state to be solid, but when I choose any of the trace options, it just leaves an outline of the state. I have attached pictures. Any suggestions Graphtec Studio is all I use with my CE-6000. The problem you're trying to solve is an easy fix. When you choose the Trace tool, you'll see you have 3 options in the Apply Trace Method window. You should be choosing the Trace Outer Edge option. When you get the trace that you want, select the object and do a Save to Library to keep it for future use. I have a library full of tracings that I've done with this program. 1 Share this post Link to post Share on other sites
