Ckovarcik
Laserpoint will not cut in correct spot when trying to Contour cut
I have bought this new cutter after using the my series and had no issues at all! Now, I have this laserpoint 2 and I can not contour cut or even get the laser to setup or calibrate correctly. I got it to set up once and it cut very close but not like it should. Now I have tried again and it is way off!!! Can not get the laser set up properly and then also will not contour cut in the correct spot. I am using the SCAL software. If someone is will please call me at 8323637015. Your help will not go unoticed!!! I am now 24 hours into trying to set it up.
Have you tried to line up the marks using the blade instead? You would probably have to adjust the software settings so that it accounts for the position of the laser. My guess is it's zeroing based on the blade. I don't own your cutter or use your software so I'm just guessing.
