aent 2 Posted November 23, 2016 Hi all, I work in construction and was toying with the idea of starting to make signs and decals in house and trying to figure out how much it will cost me, but when I noticed you can put a pen on them and use them as a pen plotter as well, I was wondering... is this good enough as a pen plotter to make construction blueprints? i.e, will the Titan 2 be able to legibly write small text/numbers that is perhaps 8 or 10 pts? Does anyone have any pictures of samples of small text out of this machine? I was leaning towards the SC series originally, and have the same questions about that machine if anyone has both? If I can't reliably do blueprints or the other one can do it too, I'd like to save the money and get that one instead. I won't be printing too many blueprints on it, most will likely go to my 13" wide format printer I already have, but some plans need to be on 24" where I currently need to run to a print shop to pick up and I definitely don't do enough volume to warrant buying a dedicated wide format printer. Or am I not being realistic hoping for a dual purpose machine? Share this post Link to post Share on other sites
Primal Decals 618 Posted November 23, 2016 I have the titan 2 28"( 24") cutter and just love it..this is where it falls with the other cutters and where the other cutters fall. I suggest dont go with a low end cutter seriously. http://www.uscutter.com/index/page/static/subpage/buying_guides_new , i will do a test on the 8-10 points for you ,Not sure if you need a special pen for doing blue prints but that titan 2 is amazing and on sale right now at an amazing price..http://www.uscutter.com/TITAN-2-Vinyl-Cutter-28-53-68-inch. I dont care for the software in my own opinion that is.Ive learned Vm and just didnt like the work around etc.I use scalps 4pro and is great..ill let you know on the test... Share this post Link to post Share on other sites
Primal Decals 618 Posted November 23, 2016 So i tried the pen plotter at 10 points and the standard pen that comes with the cutter i think is a medium point pen, and when it did write it was ok but due the being a wide pen tip it wasnt clear and made the writing to close cause its wide tip,I didnt have a fine point to put in it, but i think after seeing what it did with the medium point that a fine point should work fine.maybe someone has a fine point to put in it or i will get one later and try it and let you know the end results with a fine tip... 1 Share this post Link to post Share on other sites
aent 2 Posted November 24, 2016 4 hours ago, Primal Decals said: So i tried the pen plotter at 10 points and the standard pen that comes with the cutter i think is a medium point pen, and when it did write it was ok but due the being a wide pen tip it wasnt clear and made the writing to close cause its wide tip,I didnt have a fine point to put in it, but i think after seeing what it did with the medium point that a fine point should work fine.maybe someone has a fine point to put in it or i will get one later and try it and let you know the end results with a fine tip... Thanks so much for your information! I'm hoping someone can test it soon and post a picture, if it comes out well I'm ready to order it! 1 Share this post Link to post Share on other sites
deth502 38 Posted November 24, 2016 not knowing exactly what size that is, but knowing there are 72 points to an inch, my calculator puts 8pt at 0.1111111111" i have routinely done 1/8" letters, or 0.125", which is pretty damn close, on my mh series machine, so the titan, being a step up, should hopefully be able to do that or better, id imagine. Share this post Link to post Share on other sites
Wildgoose 3,742 Posted November 24, 2016 The biggest factor is probably the pen tip. All of the pens I have ever seen un use or used myself are felt tip not roller ball so there would be a limit to some details just from that but otherwise I imagine it would be fine. Just need a dxf file. Share this post Link to post Share on other sites
Primal Decals 618 Posted November 24, 2016 3 hours ago, Wildgoose said: The biggest factor is probably the pen tip. All of the pens I have ever seen un use or used myself are felt tip not roller ball so there would be a limit to some details just from that but otherwise I imagine it would be fine. Just need a dxf file. the tip is the biggest thing for sure.Im getting a fine tip today to test it.. 2 Share this post Link to post Share on other sites
aent 2 Posted November 24, 2016 2 hours ago, Primal Decals said: the tip is the biggest thing for sure.Im getting a fine tip today to test it.. Thank you so much! Can't wait to see it! Happy thanksgiving! Share this post Link to post Share on other sites
deth502 38 Posted November 25, 2016 i use a ball point pen. i just take a regular bic pen and wrap tape around it until its thick enough to fit in the carriage. thats all, no other mods. i never actually tried the pen attachment that came with the machine. 1 Share this post Link to post Share on other sites
signyouup 175 Posted November 25, 2016 The thing about blueprints is there are usually multiple line widths. 1 Share this post Link to post Share on other sites
Primal Decals 618 Posted November 26, 2016 By playing with the blade offset and over cut you can get it to draw pretty good.This was just a quick try with a quick setting change.. This was in scalps and the original blade setting was .30mm and offset was 1.00mm which wasnt the best. i was impressed after the setting change tho.. Oh this was used with a .07 mm fine tip pen from the dollar store. there are .05mm but you probably have to go to walmart that has a better selection.. But at least you can do this .. 2 Share this post Link to post Share on other sites
aent 2 Posted November 26, 2016 On 11/25/2016 at 1:41 PM, signyouup said: The thing about blueprints is there are usually multiple line widths. I did think of that and am aware of that issue... but thankfully the plans I print at the 24" width do not use the line width to indicate anything. I still plan to use my 13" wide format printer for most of the plans including all of them where line width matters, but saving me from having to run to the print shop 99% of the time is a big benefit. 2 hours ago, Primal Decals said: By playing with the blade offset and over cut you can get it to draw pretty good.This was just a quick try with a quick setting change.. This was in scalps and the original blade setting was .30mm and offset was 1.00mm which wasnt the best. i was impressed after the setting change tho.. Oh this was used with a .07 mm fine tip pen from the dollar store. there are .05mm but you probably have to go to walmart that has a better selection.. But at least you can do this .. Thank you again so much for all your help! I just ordered this thing... I can't wait to get playing with it next week! You definitely helped convince me to spend a few extra bucks, so my wallet should be mad and USCutter should be happy with you! lol I'm sure I'll have questions next week after I get playing with it Share this post Link to post Share on other sites
Primal Decals 618 Posted November 26, 2016 send me a message anytime and i ll try to help..what cutter did you decide on? i think if was to change the blade offset to .02 or .01 it would be even cleaner lol.. 1 Share this post Link to post Share on other sites
aent 2 Posted November 28, 2016 The Titan 2, I figured it was the cheapest cutter that could do anything I could possibly want to do 1 Share this post Link to post Share on other sites
darcshadow 962 Posted November 28, 2016 You shouldn't need a blade offset when using a pen, a setting of 0 should give the best results. Blade offset is to account for the fact that the tip of the blade is not centered in the holder. That would not be the case with a pen. 1 Share this post Link to post Share on other sites
harleyrkc 7 Posted February 11, 2017 Is there any particular pen that works well? Recommendations? 24" Blueprints will be a huge bonus for me since I hate 11" x 17". Share this post Link to post Share on other sites
bikemike 602 Posted February 11, 2017 You are limited to what will fit in the holder. I prefer a good ball point. Share this post Link to post Share on other sites
harleyrkc 7 Posted February 12, 2017 4 hours ago, bikemike said: You are limited to what will fit in the holder. I prefer a good ball point. Is there a pressurized pen option for the Titan similar to the Roland one. Share this post Link to post Share on other sites
bikemike 602 Posted February 12, 2017 If I am not mistaken, the titan use's a Roland blade holder? Share this post Link to post Share on other sites
Dakotagrafx 6,673 Posted February 12, 2017 2 minutes ago, bikemike said: If I am not mistaken, the titan use's a Roland blade holder? roland style blade- holder may differ from a conversation some one else had Share this post Link to post Share on other sites
bikemike 602 Posted February 12, 2017 Good point. who was it making holders? Maybe one for the titan? Share this post Link to post Share on other sites
harleyrkc 7 Posted February 12, 2017 Sounds like I need to call USCutter Monday and see if they have any answers. I was already excited about the plotter, but this idea has me ecstatic. Share this post Link to post Share on other sites
bikemike 602 Posted February 12, 2017 Just remember, no line width using a pen. But ya, it does work good otherwise. Share this post Link to post Share on other sites
skarekrow 1,779 Posted February 12, 2017 1 hour ago, bikemike said: Good point. who was it making holders? Maybe one for the titan? MB20music... Can definitely vouch for the sharpie holders... they have been a real asset. Share this post Link to post Share on other sites
harleyrkc 7 Posted February 12, 2017 1 hour ago, bikemike said: Just remember, no line width using a pen. But ya, it does work good otherwise. Prints for my purpose don't need dimensional lines. I install and service building automation systems, I'm just happy not having to use 11"x17" prints on an install. I mostly need equipment locations and schedules. The schematics I draw don't need to be to scale so folded 11"x17"s in a book are fine. Share this post Link to post Share on other sites
