pilotman1
laser point 2 plotter
I have a laser point 2 plotter and just now getting started cutting sister stretch, the problem is when the plotter is cutting the design every once in awhile the vinyl bunches up, therefore screwing up the design also what is the best blade to be using when cutting heat transfer vinyl.
thanks for any suggestions.
With stretch make sure you have a good sharp blade and don't cut too fast. The carrier is soft plastic and will bunch if you try to use too much force. A new blade and set the pressure just enough to get though and you should have no issues. Like regular vinyl cutting keep your blade set as short as possible. Siser stretch should't require blade depth adjustment and I usually cut at the same pressure as regular vinyl.
