kmillerkreations
Titan 3 not cutting at 0,0
Anyone have an issue with the Titan 3 not cutting where you set 0,0? I load in the material and move the blade where I want it to cut, then press Enter. When I send the image from the software to the cutter, the cutter moves the blade to the right edge and cuts there instead of where I set 0,0. What am I doing wrong?
Does it cut it all right?
0,0 is just a home point. Most start cutting as the image was designed. 0,0 may not be where you started the design.
