kmillerkreations 0 Posted November 1, 2016 Anyone have an issue with the Titan 3 not cutting where you set 0,0? I load in the material and move the blade where I want it to cut, then press Enter. When I send the image from the software to the cutter, the cutter moves the blade to the right edge and cuts there instead of where I set 0,0. What am I doing wrong? Share this post Link to post Share on other sites
bikemike 711 Posted November 1, 2016 Does it cut it all right? 0,0 is just a home point. Most start cutting as the image was designed. 0,0 may not be where you started the design. Share this post Link to post Share on other sites
