dave1510 1 Posted October 21, 2016 How can you cut one file after another without going to the file, cut it, then having to go to another file and cut it, so on and so. Just setup your plotter and go. Quote Share this post Link to post Share on other sites
Guest VinylMaster Support Posted October 21, 2016 There are two ways you can easily do this: In the Vinyl Spooler, you can change from viewing only the most recent file to viewing all files (top toolbar option), and then simply select multiple cutfiles. You can do this by holding down the Shift key when you select additional files, or even using the CTRL key to add/remove individual items. All of the selected cutfiles will be auto arranged, and you can turn on/off the Auto Save Media option to change the way it is packed. If you have VinylMaster PRO, you can use the Cutfile Document, and send multiple jobs to the same cut document and arrange them all before sending to the cutter. 1 Quote Share this post Link to post Share on other sites
