bh0307 12 Posted October 19, 2016 Got a brand new titan 3 when I am cutting to images side by side the one on the left get little tear hole in it like you shot it with a shot gun , the right side cuts fine. Anyone seen this ?? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 19, 2016 call support - the one side looks like it is pulling the vinyl up like too much blade exposure but if that was it it should be doing it on both sides too Share this post Link to post Share on other sites
bigfrank 16 Posted October 20, 2016 Look at your cutting strip were the blade runs. If there are cut marks in it, like maybe you cut too deep or cut off the vinyl at some point, it will do this If this is the problem, take a piece of clear packing tape and put it over the cut marks. I had this same problem. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted October 20, 2016 Double check you file for stray nodes too. I can't tell from the pics but it looks like there are a bunch of cuts outside the image that would be garbage left from an auto-trace Share this post Link to post Share on other sites
bh0307 12 Posted October 24, 2016 Thanks For all the help . I put in new blade adjusted it. slow down my speed and not as much forge, Everything seem to be working fine now, Guess just been Newbie lol. Here is one after the adj. still learning alot. Share this post Link to post Share on other sites
