parso57
Mutoh Value Cut with Signblazer
have just updated to a new cutter, Mutoh VC1300 Value Cut and have run Signblazer for the last 14 years. Updating software to SAI Flexi, need to convert SBD files to EPS or PDF to save old work into new RIP. is there a driver for VC1300 for Signblazer or better to transfer files to new software?
Since you are migrating into Flexi, you will just have to EXPORT your cutting files as .eps and go from there.
If you prefer to retain the ability to cut those older files directly as needed from SB, you might just try creating a small test SB file and choosing one of the Mutoh cutters from the list in Setup, and give it a try. Continue on down the list until you get SB to talk to your cuttter! (You may even get the Mutoh to work with Copam driver, Roland, or even Creation ---  try 'em all)
