JarretAVFC 0 Posted September 25, 2016 Help required. The z axis on the cutter does not go up/down during a cutter programme. With no power to the machine the solenoid holds the cutter in the up position, when the power is turned on the cutter blade drops down, and when i run a programme it does not go up/down. Everything else appears to work fine. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 25, 2016 my bet is on the mainboard then - I don't believe the z chip was replaceable on the p-cut. Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 25, 2016 There is a Z-axis controller chip which is susceptible to being toasted with excess static electricity charge. I had the MH unit which actually puts the z-chip mounted within a receptacle on the motherboard. Changing out a blown zchip is a breeze (pop the fried one, insert the $5 new one). On the machine you have, the zchip is probably soldered in place and requires some electronics skills to swap it out. Share this post Link to post Share on other sites
