long644
Contour cutting US Cutter MH creates a vertical cut at end please help!!!
Hi I'm new to this vinyl hobby . I have a 14" desktop MH Us Cutter . I'm using VM 4.0. I start off uploading the image then vectorizing it . After that I want to do a contour cut set that up and do contour wizard before cutting. Cuts fine til the end of cutting it always have a vertical Cut straight through my image. I used a pen plotter to demonstrate what's happening. Please help. Thanks
wow even doing it on the test cut. Is the test cut done through VM4? Can you do a test without the program on that cutter? Some will do it if you press a certain key combination.
Have you registered VM?
i believe some of the software will put a line thru when sent to cut if not registered, but I'm still new to this so ymmv :)
