Guest obrockmeier Posted September 13, 2016 Trying to import a DXF file (perf test.DXF) generated in my CAD software (solidworks) and nothing happens. The file is confirmed good by two other programs (Draftsight and edrawings). I can export a dxf from Vinylmaster Cut (testExport.DXF) and then re-import that dxf file back into Vinylmaster Cut no problem. perf test.DXF testExport.dxf Quote Share this post Link to post Share on other sites
kbenz 0 Posted September 14, 2016 I can import a dxf from mine fine. but yours won't import??? Quote Share this post Link to post Share on other sites
Guest Toby Posted September 14, 2016 Try converting the DXF file to PDF using http://www.dxfconverter.org/ and it should load in correctly. Quote Share this post Link to post Share on other sites
obrockmeier 0 Posted September 19, 2016 The problem seems to have been due to a DXF file with nothing but circles, it somehow confuses the software. The workaround is to draw another shape, a rectangle, around them. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted September 19, 2016 Yes, this issue has since been identified and corrected. These changes and others will be applied to the next update due out shortly. Quote Share this post Link to post Share on other sites
Jake99 0 Posted February 9, 2017 Has this been done? I'm experiencing the same thing now. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted February 9, 2017 This webpage has the very latest builds of all USCutter versions:http://fcws1.com/usc1.htm 1 Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted February 10, 2017 1 hour ago, VinylMaster said: This webpage has the very latest builds of all USCutter versions:http://fcws1.com/usc1.htm Submitted my Serial Number and it displays "Invalid PSN" Edit: I see now where this is for Vm Purchased through US Cutter... What about those of us that Purchased Directly? Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted February 10, 2017 For non-USCutter updates please go to this webpage: http://iifuture.com/vmfull/getvm.htm 2 Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 10, 2017 Can I say, SOOO nice to have you guys tech supporting the VM on the forum. Great job and IMO one that will insure success for the long haul. Quote Share this post Link to post Share on other sites
Guest Ditka Posted October 10, 2017 So I can bring in a DXF but its not at the right size. Is there a setting that I need to know about? Quote Share this post Link to post Share on other sites
