arcticmonster 4 Posted August 22, 2016 I am just a hobby vinyl cutter for some of my own stuff. I have a SC34 and Corel X3. What is the cheapest way for me to be able to cut my designs without purchasing SIGNCUT. I have tried Signblazer elements, but anything I import gets distorted. Vinyl Master is a cheaper alternative, would that work better? Thanks. Share this post Link to post Share on other sites
Sue2 920 Posted August 22, 2016 I like VM Cut...it works/feels similar to Corel. BUT, I create in Corel and import the eps file into VM for cutting. Previously I used SignBlazer for cutting and still have it on one computer. Sue2 Share this post Link to post Share on other sites
arcticmonster 4 Posted August 22, 2016 What did you export as from Corel to be able to use in Signblazer? I will most likely get VinylMaster. thanks. Share this post Link to post Share on other sites
Sue2 920 Posted August 22, 2016 Convert all text to curves & export/save as eps. eps files should work in most cutting programs. Sue2 Share this post Link to post Share on other sites
castironrobbie 30 Posted August 31, 2016 Isn't the base SCAL only like $50? Correct me if I'm wrong. Great program 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted September 1, 2016 On 8/31/2016 at 3:53 AM, castironrobbie said: Isn't the base SCAL only like $50? Correct me if I'm wrong. Great program very great program ,but i have the pro version $199.00. which is better than the base version $59.00 There is a difference for sure.. Share this post Link to post Share on other sites
knucklehead 530 Posted September 2, 2016 Back in the days, before 200 dollar vinyl cutters, we used to use single edge razor blades/ X-Atco knifes, to cut paint mask, and stuff. Pretty cheap. 3 Share this post Link to post Share on other sites
castironrobbie 30 Posted September 4, 2016 On 9/1/2016 at 5:10 PM, Primal Decals said: very great program ,but i have the pro version $199.00. which is better than the base version $59.00 There is a difference for sure.. Same here brother. Just making a suggestion. I use SCALP 3 1 Share this post Link to post Share on other sites
mrfibble 77 Posted September 4, 2016 I have SCAL regular version not pro but only because i cant afford the pro version i have heard that Pro is worth it though so ill be upgrading to that eventually David Share this post Link to post Share on other sites
Primal Decals 621 Posted September 5, 2016 5 hours ago, mrfibble said: I have SCAL regular version not pro but only because i cant afford the pro version i have heard that Pro is worth it though so ill be upgrading to that eventually David sending you a pm.. i have some info for you about upgrading thru craftedge. Share this post Link to post Share on other sites
castironrobbie 30 Posted September 5, 2016 10 hours ago, Primal Decals said: sending you a pm.. i have some info for you about upgrading thru craftedge. I want some info too. I have 3 but think I read 4 is now available Share this post Link to post Share on other sites
crome 53 Posted September 6, 2016 14 hours ago, castironrobbie said: I want some info too. I have 3 but think I read 4 is now available http://www.craftedge.com/purchase/craftedge/purchase_scal4pro.php Upgrade from pro 3 to pro 4 for $49.99 1 Share this post Link to post Share on other sites
