arcticmonster
Cheapest way to Cut question
I am just a hobby vinyl cutter for some of my own stuff.
I have a SC34 and Corel X3.
What is the cheapest way for me to be able to cut my designs without purchasing SIGNCUT.
I have tried Signblazer elements, but anything I import gets distorted.
Vinyl Master is a cheaper alternative, would that work better?
Thanks.
I like VM Cut...it works/feels similar to Corel.
BUT, I create in Corel and import the eps file into VM for cutting.
Previously I used SignBlazer for cutting and still have it on one computer.
Sue2
What did you export as from Corel to be able to use in Signblazer?
I will most likely get VinylMaster.
thanks.
Convert all text to curves & export/save as eps.
eps files should work in most cutting programs.
Sue2
On 8/31/2016 at 3:53 AM, castironrobbie said:
Isn't the base SCAL only like $50? Correct me if I'm wrong. Great program
very great program ,but i have the pro version $199.00.  which is better than the base version $59.00
There is a difference for sure..
Back in the days, before 200 dollar vinyl cutters, we used to use single edge razor blades/ X-Atco knifes, to cut paint mask, and stuff. Pretty cheap.
  • Like 3
Same here brother. Just making a suggestion. I use SCALP 3
I have SCAL  regular version not pro    but only because i cant afford  the pro version     i have heard that Pro is worth it though    so  ill be upgrading to that eventually
David
David
sending you a pm.. i have some info for you about upgrading thru craftedge.
I want some info too. I have 3 but think I read 4 is now available
