Hummer 21 Posted August 17, 2016 As the title suggests, can I apply polyacrylic over vinyl on a stained board? This will be an indoor project. I did look through the archives but couldn't find a definitive answer. Thank you for your time... Share this post Link to post Share on other sites
Cal 393 Posted August 18, 2016 Additional questions for you. I think the polyacrylic is water base? Is your stain water or oil base? What vinyl will you use? I think you could, but if you put water base product over a water base stain, it might affect the stain underneath. I would try on some scrap first. Cal Share this post Link to post Share on other sites
Hummer 21 Posted August 18, 2016 The stain is oil based. I am using FDC vinyl. I think that I had better test this out first. Thank you for your input. I just wasn't sure whether the water based urethane would affect the vinyl. I have used polycrylic over oil based stain on numerous occasions with no issues. I just let the oil stain dry (off gas) for a couple of days first. Share this post Link to post Share on other sites
