Hummer
Polyacrylic over vinyl on stained wood sign...yea or neigh
As the title suggests, can I apply polyacrylic over vinyl on a stained board?  This will be an indoor project.  I did look through the archives but couldn't find a definitive answer.
Thank you for your time...
Additional questions for you.  I think the polyacrylic is water base?  Is your stain water or oil base?  What vinyl will you use?
I think you could, but if you put water base product over a water base stain, it might affect the stain underneath.
I would try on some scrap first.
Cal
The stain is oil based.  I am using FDC vinyl.  I think that I had better test this out first.  Thank you for your input. I just wasn't sure whether the water based urethane would affect the vinyl.  I have used polycrylic over oil based stain on numerous occasions with no issues.  I just let the oil stain dry (off gas) for a couple of days first.
