CUTALOT 0 Posted August 1, 2016 Hello, Just purchased a new CS630 (was still sealed in bag in original box). I cannot seem to get it to cut on either serial or USB. I am running Vista 32-bit and Signblazer. The computer recognizes the machine when I plug in with USB and I can send a test file to the cutter with Signblazer but nothing happens. When I am using the serial cable, the lcd on the cutter says "com0-Connection" but on the computer the actual com port is Com2?? Signblazer sometimes - fails to initialize the cutter.. but then I change the baud rate and it trys sending it to the cutter. I believe my issue is with the settings but any help would be great. I was trying the standard settings for serial connection 9600 baud rate, flow control - hardware. Does the driver settings and the signblazer settings need to match? Thank you! Share this post Link to post Share on other sites
