younameitvc 1 Posted July 31, 2016 When printing my logo or image for contour using Epson WF7610 it is also printing very vague parts of the dotted contour cut line in blue. It is not the entire dotted line but here and there around the image. When I perform my contour cut my offset is pretty spot on but this line bleeds into my image a tad. How do I tell it to not print that line? Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted August 1, 2016 The true tech all chime in soon but I would think you can turn off that layer when you print so only the registration marks print and the graphic print and not the outline. I have the program but am not anywhere near contour cutting with it at this point. I'll try to make time to play with it tomorrow if someone more knowledgeable doesn't post up before that. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted August 1, 2016 What steps are you undertaking to create the print file as the contour cut line is not generated by the software for printing. Quote Share this post Link to post Share on other sites
younameitvc 1 Posted August 1, 2016 I select the image and hit Trace. ( Images detected do you wish to include their auto traced contours ). I click yes and it traces. I then select Output Options ( Use a Contour Cut ). I click accept and then select all and go to Contour Cut Wizard. Select my print options and registration options etc. Then I print. It then prints the image and vary vague spots of the blue contour cut line around the image very close to where the cut is. Quote Share this post Link to post Share on other sites
Go-C Graphics 856 Posted August 1, 2016 1 hour ago, younameitvc said: Damn, I can't help you but my dirty mind thinks you're tracing a set of boobies. LOL I'm sorry. Back to figuring out your problem. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted August 1, 2016 That looks like some type of artifact which is being created or was always a part of the artwork and is being amplified in some way. I suggest doing the whole operation in the Contour Cutting wizard as it traces in there as well. Vectorizing and contour cutting are used for separate processes and are not the same thing. You can also upload the artwork to: Future Support So a tech can take a look at it. Quote Share this post Link to post Share on other sites
