tshirtman22 0 Posted July 18, 2016 I have a few questions. Just purchased a SC Cutter to do contour cutting or I thought. Here is my question/request for assistance. After I print out my design on Jet Pro Stretch paper from my inkjet printer, how do I get the print out to the SC cutter to cut out the outline? Any help/videos would be appreciated. Thank you Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 18, 2016 What level of Vinyl Master are you using? Do you have any of the file Vectored? DO you understand what that means? At the end of the day you will need a line for your cutter to cut. If you are running a version of Vinyl Master that does this (some lower tier levels may not have this feature) You would go to File>Contour Cutting>Create Cut Contour (or Contour Cut Wizard within the same file path). Just an FYI contour cutting with a manual machine like the SC will only yield so-so results so don't expect perfect registration. I recommend leaving a decent amount of safe zone around the edges because you are going to have to manually line up the cutter to the marks and there will be a margin of error. True contour cut machines have optical eye systems that will actually read the marks and get the alignment spot on. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted July 18, 2016 You may find this lesson helpful: Contour Cutting using Ultra Marks 1 Quote Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted July 18, 2016 jpss I never even cut it - 3g opague I did but the carrier on jpss is clear Quote Share this post Link to post Share on other sites
tshirtman22 0 Posted July 19, 2016 Yes,thank you for your help. I do know what vectored means. I am learning a lot by just reading too. I have Vinyl MasterCut 4.0 4 hours ago, Wildgoose said: What level of Vinyl Master are you using? Do you have any of the file Vectored? DO you understand what that means? At the end of the day you will need a line for your cutter to cut. If you are running a version of Vinyl Master that does this (some lower tier levels may not have this feature) You would go to File>Contour Cutting>Create Cut Contour (or Contour Cut Wizard within the same file path). Just an FYI contour cutting with a manual machine like the SC will only yield so-so results so don't expect perfect registration. I recommend leaving a decent amount of safe zone around the edges because you are going to have to manually line up the cutter to the marks and there will be a margin of error. True contour cut machines have optical eye systems that will actually read the marks and get the alignment spot on. Thank you, will watch here shortly. 4 hours ago, VinylMaster said: You may find this lesson helpful: Contour Cutting using Ultra Marks Yes, it is clear but still shows a white box sometimes. I would rather just press the image etc.. I am more worried about the opague paper vice jpss. Thank you once again. 3 hours ago, Dakotagrafx said: jpss I never even cut it - 3g opague I did but the carrier on jpss is clear Quote Share this post Link to post Share on other sites
