MadHatterGraphix 1,258 Posted July 15, 2016 I'm interested in knowing if there is a place I can get full sized T-short templates so I can use it to design around sleeves and such? Share this post Link to post Share on other sites
skarekrow 1,842 Posted July 15, 2016 I'd say just make your own from a foto you've taken of an actual shirt you intend to create. Drag the raster foto right into your design software and create/place the image right over top. You could redraw or auto vector the foto for a permanent, resizeable template but, I suggest photographing All your needed size shirts cause you know the proportions vary. This will give you a real-world examples with the ability to measure the intended areas of different size garments. Share this post Link to post Share on other sites
Monkey 252 Posted July 15, 2016 Their called T-shirt Comps. Some add on programs for CorelDraw come with them. I use them all the time when sending design for approval to customer so they can see it on a shirt in the colors they want. Its been beneficial in showing a stubborn customer some colors just dont work well together when they dont believe you when you tell them. Share this post Link to post Share on other sites
Primal Decals 621 Posted July 15, 2016 not sure if this helps but i started searching for this for you to help out..ill keep looking https://www.google.com/search?q=360+degree+t+shirt+templates+for+illustrator&safe=active&biw=1859&bih=861&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiNqKHAmvbNAhUW_mMKHRdfBL0QsAQIRA https://www.google.com/search?q=360+degree+t+shirt+templates+for+illustrator&safe=active&biw=1859&bih=861&source=lnms&tbm=isch&sa=X&ved=0ahUKEwixnsHbmvbNAhVRxGMKHdi9BYYQ_AUIBigB#safe=active&tbm=isch&q=t+shirt+sleeve+templates+for+illustrator http://all-free-download.com/free-vector/vector-t-shirt-sleeve-template.html http://www.vectorportal.com/category/templates/iType/182/offset/2/ http://www.vectorportal.com/category/templates/iType/182/offset/4/ Scroll down thru the list on this page---- http://www.designbolts.com/2014/05/02/50-free-high-quality-psd-vector-t-shirt-mockups/ Share this post Link to post Share on other sites
