kainth.c.s
The cutter movements on the panel and in actual not the same
Hi Guys
I have encountered a strange problem
I have Creation PCUT CT630 cutter with 1.5 mm Blade shank. I noticed that the movements I make using the arrow keys on the control panel are way too more than what we check thereafter. Let's say I move the cutter 400mm in Y from its Zero position using the arrow keys. The panel shows Y=400.00, but when I take the cutter back to its zero and chek using a tape measure, I ge something around 250!!!!!!!. However, when it cuts, it cuts to the correct size
I use flexi 10 for files and flexi 10 production manager for the cutter.
Please help
