Apollomrqz 0 Posted July 6, 2016 i have drawn a semi detailed image in illustrator. when i go to cut it, the plotter overlaps parts of the image. an example is attached. picture a checker board with no fill just stroke. a few thousands of an inch gets overlapped over some of the squares. i drew it up in illustrator (vector) once done i expanded it and united everything(welded) then sent to my cutting software called stonecut. any and all help is much appreciated, thank you Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 6, 2016 Doesn't look like you got it completely welded or your cutter is just off-tracking (a common problem) but it's hard to tell in the pic. If you can post the cut file that would help a lot. It has to be 1000kb or less so you might have to save it to an svg for size. Share this post Link to post Share on other sites
