Jbtynes
Corel X8 windows 10 issue.
I recently upgraded my main graphics station to Windows 10. I can no longer cut from corel x8. I understand the whole "corel isn't cutting software" but it has worked great for me. I have a 53" titan 3 and installed the uscutter drivers and "print" to it from corel directly.
Does anyone else here do that and had any issues with Windows 10? I suspect it's the driver but I don't know. I did a clean install on win 7 on my laptop and it cut first try right from corel again.
I have the same problem I upgraded to coreldrawx8 since then I can no longer cut using corel I don't see the cutter plogin for cuting master3 using my grahptec cutter I have been looking macros is empty laoncher is empty if any body knows how to cut in coreldrawx8 using windows10
please tell me . Thank you
I can not make it work in my windows10
I cant remember how now (it's been a few months) but I got it to work again. however, it cut terrible. cuts didn't meet, and I mean no cuts would meet. every letter had about a mm left uncut. graphics larger than 10 inches would miss by a quarter inch. I ditched cutting from corel and started exporting to scalp. all problems resolved. cuts are perfect again. it does a much better job of handling larger cuts too. it doesn't skip around like corel would. Corel would cut in the order you drew the objects.
I never had the incomplete cuts issue cutting from corel directly with x7 and Windows 7.
I strongly recommend another cutting program and just export to it.
Jt
