Pebbles1488
Cutter not cutting
My cutter was working FINE!  I have the Refine MH721, using the RedSail RS720C settings on the UK version of Sign Blazers.  Now all of a sudden, on the SAME port it's been on since I set it up, NOTHING!  HELP!
I know this sounds odd but sometimes I will get a static charge that gets past the ground wire and when my cutter freezes I have to reboot the computer as well to get it to start working again. This is rare mind you but it does happen.
check your settings for the output in signblazer - for some reason those go wonky on those cutters for some reason - that is after a computer reboot and cutter power off and on
