kkeeble 64 Posted June 7, 2016 Does anyone know where i can get the color codes for siser easyweed.. Thank you Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 7, 2016 Being your printer uses cmyk that should be the appropriate setting. Rgb is the format for light emitting devices like a monitor. Printers don't emit light and use Cyan, Magenta, Yellow, and K is for black (can't remember the technical reason right now for the use of k Share this post Link to post Share on other sites
kkeeble 64 Posted June 7, 2016 Thank you.. Ive seen the color codes before but can not remember where.. im trying to match a color and need something close. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 7, 2016 Being your printer uses cmyk that should be the appropriate setting. Rgb is the format for light emitting devices like a monitor. Printers don't emit light and use Cyan, Magenta, Yellow, and K is for black (can't remember the technical reason right now for the use of k looked it up and K stands for key - which is black. I started in radio and tv repair so back then everything like a crt uses RGB to produce colors with light - the 3 together produce white light. in printing the substrate is the white and you add the colors to produce black or with black ink to produce the truest black . so your monitor uses one standard and your printer the other Share this post Link to post Share on other sites
skarekrow 1,842 Posted June 7, 2016 VinylMaster Pro has a Color Library that displays lots of vinyls but I don't see EasyWeed listed. Hexis is listed but not Siser. Share this post Link to post Share on other sites
kkeeble 64 Posted June 7, 2016 I just spoke to Traci over at Siser.. They have RGB, HEX and Pantone. She doesnt have a list that she can send to me but is willing to send me the information if I ask for certain colors. The RGB for Navy Blue Easyweed is: R=55 G=62 B=75 Sun Yellow Easyweed RGB Values R=255 G=172 B=0 Share this post Link to post Share on other sites
skarekrow 1,842 Posted June 7, 2016 You can pull a color swatch into Photoshop and get that info as well. Share this post Link to post Share on other sites
