cam.lowe.sc@gmail.com 0 Posted June 4, 2016 Hello, Is there a good software program that will vectorize images easily? I use inkscape and trace bitmap, but whether the "smooth" or "smooth corners" boxes are selected or not, the image always turns out funky. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 4, 2016 Fonts are traced as a last resort. Find the font..and use it. Most all vector programs will require some clean up of nodes after vectoring..It takes practice. I thought Inkscape was pretty good .the few times I used it. Scalp has a vector program as well as Vinyl Master.. Then there are others like Vector Magic, which you also will have to pay for. There are some good tutorials out there for it. And youtube videos https://inkscape.org/en/doc/tutorials/tracing/tutorial-tracing.en.htmlhttps://inkscape.org/en/doc/tutorials/tracing/tutorial-tracing.en.html 2 Share this post Link to post Share on other sites
knucklehead 530 Posted June 5, 2016 I've sent a couple off to Fivver, to get vectorized. It was pretty easy. Share this post Link to post Share on other sites
Primal Decals 621 Posted June 5, 2016 vector magic is pretty dang good for images i meant to say. but never try to trace fonts.. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 5, 2016 I'm with skeeter - never trace a font - find it and use the font for the cleanest results 2 Share this post Link to post Share on other sites
darcshadow 1,626 Posted June 7, 2016 As others said, don't trace a font. From the image you posted however, looks like you also need to tweak your trace settings. It appears you were using either Color Quantization, or one of the Multiple Scans options. For a simple black and white image you want to use the Brightness cutoff. I usually start my threshold to 0.65 and the adjust as needed. Tweaking the items on the Option tab can help as well. But getting a good trace of a font is nearly impossible. Share this post Link to post Share on other sites
