BNS16 0 Posted June 1, 2016 I have an image I imported and I looking to layer the image with colors to cut. How can I fill in the image with colors?.... Thank you Its just a wire frame image at this point. Quote Share this post Link to post Share on other sites
Primal Decals 621 Posted June 1, 2016 can you post your file or jpeg image so we can see what your talking about . Quote Share this post Link to post Share on other sites
Dawn's Design 403 Posted June 2, 2016 We also need to know what software you work with... Quote Share this post Link to post Share on other sites
BNS16 0 Posted June 2, 2016 I have these on my T-Shirts. I wanted the same loco to make and I have the out line traced and is just black and white. I wanted to fill in the side panel and the nose of the kart with a color. There is no yellow in/on my design in Vinylemaster LTR.. Hope you can help me. Thank you... Quote Share this post Link to post Share on other sites
BNS16 0 Posted June 2, 2016 Where there is yellow is white. Im ok with that. I just wanted to add side panel color and the front hood color.. ... Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted June 2, 2016 Don't know how vinylmaster works but in Inkscape I'd duplicate the cart then inkscape a box behind it and then use the difference tool, called punch in some software, and subtract the card from the box. then just delete the left over portions of the box that I don't need. There may be a better/easier way, but without seeing the vector file it's hard to say. Quote Share this post Link to post Share on other sites
Dawn's Design 403 Posted June 2, 2016 I use coreldraw. They have a tab that's called auto fill. You just click it then click on what you want filled. It fills with a light Grey that you can change to any color you want. If you can post the vector someone might fill it for you the you could change the color to what you want. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted June 2, 2016 You could use the curve tools to draw the shapes and place them below the cart (send to back). Would take a minute, perhaps two to do (easiest by far)... or, If you have it as vectors you could place a square behind the cart and use Punch out to create the hood/door shapes and then using break apart delete all the extra parts as darcshadow explained above. Drawing the curves would be by far the easiest. Quote Share this post Link to post Share on other sites
BNS16 0 Posted June 3, 2016 Im guessing there isnt an easy way to do this. Any other thoughts on a different vrs of software or a different soft ware to be able to do this. Im sure this wont be my last image that I would like to do this with. Quote Share this post Link to post Share on other sites
BNS16 0 Posted June 3, 2016 I use coreldraw. They have a tab that's called auto fill. You just click it then click on what you want filled. It fills with a light Grey that you can change to any color you want. If you can post the vector someone might fill it for you the you could change the color to what you want. This is what i was hoping to do was the fill option. I might be interested in switching software. What would u switch too if you were looking...? Quote Share this post Link to post Share on other sites
dcbevins 340 Posted June 3, 2016 I use coreldraw. They have a tab that's called auto fill. You just click it then click on what you want filled. It fills with a light Grey that you can change to any color you want. If you can post the vector someone might fill it for you the you could change the color to what you want. In Draw also called smart fill. Inkscape's paint bucket acts like a smart fill. In both software, it only works well on closed areas. For vinyl cutting it fits the bill. But note that sometimes smart fill does not fill the area exactly, leaving gaps. More so in Inkscape, though there is a threshold setting that helps. Often it is not enough to be a bother for cutting vinyl, but for doing other precision things, (web graphics,) it can be a problem. The boolean operations darcshadow mentioned, difference or punch out, will be precise. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted June 3, 2016 What is required by the user here, depends on the construction of the artwork itself. Take the hood for example. Is this a solid shape being drawn as a hole? or Is it a shape that appears to exist because of the elements that when put together give the observer the illusion of a hood. If 1. then this is very easy to do, simply work in wireframe (Ctrl+W) and: select the whole object break the curves apart (curve menu) select the hood and take a copy of it (+ on the keyboard) move the copy away from the artwork select everything but the copy and combine the curves (curve menu) select the copy change the curve direction (2nd row in Node edit mode) make it the required color and send to back (1st row of tools) move it to the correct position Job done... Alternatively, extracting the hood shape and using this with punch out or common (depending on your design techniques) will end up with a solid hood shape that you can then fill with whatever color you wish. If 2. then this requires a different approach because an area that is appears to exist because of a construction of elements around it, means there is no solid shape to fill (law of the Universe). In this case and as mentioned above, it would take very little time and effort to draw out the hood and door... In all cases, and with all software there will always be a series of steps to undertake in this case and a degree of difficulty depending on the construction of the artwork and training/experience of the user. Quote Share this post Link to post Share on other sites
Guest Kip stockwell Posted June 7, 2016 It worked thank you. I will post a pic tomorrow. Option #1.... Quote Share this post Link to post Share on other sites
