JuliaTN 3 Posted May 24, 2016 Any idea what could be causing this offset? The squares and the flower are somehow moved over from their original spot so that they overlap with another image. Using a Titan 2 with VinylMaster Cut on 24" wide Oracal 651. Pinch rollers are all in the right spots and there's a good bit of the roll spooled off before cutting so that there isn't any weight on it. Quote Share this post Link to post Share on other sites
Wildgoose 4,082 Posted May 25, 2016 Moved you to the VinylMaster section. I think this will receive more support here. Quote Share this post Link to post Share on other sites
JuliaTN 3 Posted May 25, 2016 Thanks, I wasn't sure if it was a software or a hardware issue. Quote Share this post Link to post Share on other sites
VinylMaster 143 Posted May 25, 2016 It looks like those two items were accidentally selected and then nudged to the right and then sent to the cutfile. Have a look at the preview in the Vinyl Spooler - it should match what was physically cut. If not you can select the cutfile and send it to a location on your HDD (see Send to > Broswe at the bottom of the Vinyl Spooler) and attach the .cut file and email it to support@future.support Quote Share this post Link to post Share on other sites
JuliaTN 3 Posted May 25, 2016 The screen shot of the cut file was done after the cut (without touching it). The 526 <squares> Rebel Ridge Rd were all grouped together so any nudging should have moved the whole thing. I did the same cut file again and got a similar result. It was a different part of the file but the same looks-like-it's-been-nudged problem. Sending file to support. Quote Share this post Link to post Share on other sites
Guest Guest Posted June 7, 2016 This issue is still ongoing and I haven't gotten any help through emailed support. It's now been 12 days without a response. Quote Share this post Link to post Share on other sites
JuliaTN 3 Posted June 7, 2016 ^^That was me, by the way. Quote Share this post Link to post Share on other sites
Wildgoose 4,082 Posted June 7, 2016 Hmmm. Maybe you've stumped the tech. I don't have VM but I have a question. In the pic what are the lines? (see redline detail) Are those weeding lines or tiling lines and did you draw them in the design or add them with the software when you got ready to cut? You might post the file if you can (preferably in a format like eps, svg or ai) Quote Share this post Link to post Share on other sites
MZ SKEETER 4,434 Posted June 7, 2016 So you have your pinch rollers set at approx the same distance in on each side of the vinyl? Just inside the vinyl? As you should be. You don't state how fast you are running your cutter, but if you run slow, do you get the same results? Quote Share this post Link to post Share on other sites
signyouup 176 Posted June 7, 2016 Is the movement in the same direction as the vinyl feeds? Were the out of position things cut last? If so something possibly caused the vinyl or feed rollers to slip. Quote Share this post Link to post Share on other sites
JuliaTN 3 Posted June 7, 2016 @Wildgoose, I drew those lines as my own style of weeding lines (I find the automatic ones don't work well with my designs). They're literally just "polylines" drawn with the software @Mz SKEETER, pinch rollers are at widest settings - there's about an inch of vinyl to the outside of outermost pinch rollers. I've had the same results running at about 750 and 550mm/s @signyouup, it's random all over the cutfile. I've attached a screenshot of the latest f-up and highlighted the parts that are out of whack. At the top, my drawn in line cuts through the "1" of 15, in the middle, the space between Compound and Loop has disappeared and for the 9009, the first 0 is overlapped with the first 9 and the interior circle of the second 9 is out of sync with the outer portion of the cut. Quote Share this post Link to post Share on other sites
Wildgoose 4,082 Posted June 7, 2016 Have you tried any other cutting software? If not try the free 7 days of SignCut Pro and see if it still does this. If it does then it's your cutter or cutter drivers, if it doesn't then it's within VM. You just have to change the variables to narrow down the issue. Quote Share this post Link to post Share on other sites
Coaster36 327 Posted June 7, 2016 Have you viewed the file in wire frame? Maybe there is something hidden under your file. If all else fails I would redraw everything in a new file. Maybe its corrupted. That's a weird problem. Quote Share this post Link to post Share on other sites
JuliaTN 3 Posted June 7, 2016 After spending 45 minutes on the phone with US Cutter tech support, it seems to have been some glitchy/corrupted software from Vinyl Master. With updated software, I'm crossing my fingers and tentatively calling it solved. 1 Quote Share this post Link to post Share on other sites
Guest Future Corporation Support Posted June 10, 2016 There is no possible way the software can arbitrarily move a single contour for no reason, while keeping all the rest in the correct location. The most likely cause of your problem will be that the cut file is just a bit too wide for the cutter, and during cutting the cutting head may happen to move too far to the left and touch the left edge, which could cause such a problem to happen.Another possibility is static buildup on the cutter. Quote Share this post Link to post Share on other sites
