Rohodyer 1 Posted May 23, 2016 I'd like to know if I can curve/arch text in VM Cut, or do I need to upgrade? Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted May 23, 2016 Yes you need to upgrade. Arc text is in Ltr and Pro, not Cut. Quote Share this post Link to post Share on other sites
busterbay 326 Posted May 23, 2016 You can do it in Inkscape for free - 3 Quote Share this post Link to post Share on other sites
Rohodyer 1 Posted May 23, 2016 Thanks guys. Great info! I'll probably do both. The more tools the better. 1 Quote Share this post Link to post Share on other sites
Guest Michelle Posted February 27, 2017 How do you upgrade your program? Do you have to pay for it? Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted March 4, 2017 The USCutter edition of VinylMaster can be upgraded from: CUT to LTR, PRO or DSR LTR to PRO or DSR PRO to DSR Upgrade cart:USCutter Upgrade Cart Quote Share this post Link to post Share on other sites
Guest Tonya Posted June 16, 2017 How do I arc a number? Not tilt it but arc it? Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted June 16, 2017 VinylMaster has several Tools for Manipulation Text to what they term "Arc". Not sure about the 'Cut' Version but, in Vm 'Pro', Text can be modeled in an arc with the the Distortion Tools like the Envelope or Arc Templates as well as the with the "Text Styles" (circle) Tool. Can you be a little more descriptive as to what you are trying to accomplish? Quote Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 16, 2017 Be aware that arc and arch are two different things. In VinylMasterCut (basic version), there are just 3 Distortion options for text -- Flag, 2D and Cylinder. Using Cylinder mode, you can manipulate the text to arch. There is no option, however, to follow a circle/circumference path (arc). 1 Quote Share this post Link to post Share on other sites
Guest CALEB is pissed Posted November 16, 2017 SO BASICALLY WHAT ELSE DOES THE VM SOFTWARE NOT HAVE THAT i WOULD THINK IS BASIC STANDARD.... HATED SURE CUT BUT WHY SWITCH TO THIS Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted November 16, 2017 Compare versions: http://www.fcws3.com/compare/ Why you might upgrade: Quote Share this post Link to post Share on other sites
Primal Decals 621 Posted November 16, 2017 18 hours ago, Guest CALEB is pissed said: SO BASICALLY WHAT ELSE DOES THE VM SOFTWARE NOT HAVE THAT i WOULD THINK IS BASIC STANDARD.... HATED SURE CUT BUT WHY SWITCH TO THIS Ya sure cuts alot still needs to fix this issue, thats the only down fall i hated as far as i can remember lol. now I use ai to design in mainly with the arch feature etc 99% and then use scalps for shadow and cutting., Perfect match and easy. I have played with Vm but still cant myself to like it yet. Quote Share this post Link to post Share on other sites
Guest red Posted September 29, 2018 Vinyl Master pro - how do you make the curved text at the bottom? Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted September 29, 2018 48 minutes ago, Guest red said: Vinyl Master pro - how do you make the curved text at the bottom? Looking at a youtube.com video. It is arc text. Check out the video. Easy to find arc text in Vinyl Master in youtube.com search. Quote Share this post Link to post Share on other sites
Guest Adam Posted March 16, 2019 I am struggling to do this as well. I have VinylMaster LTR, which is one step up from 'cut'. I have the ability to create arc text, however i do not see any way to make the text on the bottom of the arc instead of the top. I watched the youtube video re:arc text, and when he selects the text the buttons automatically show up that he refers to as 'text flows' which is what determines if the text is on top, bottom, or both. I do not have those buttons. as far as i can tell, with vinylmaster LTR, the only arc text i am able to do is on top of an arc. can someone confirm this is indeed the case, or are these buttons hidden somewhere in my version? or am I just blind and not seeing these buttons? Quote Share this post Link to post Share on other sites
haumana 1,220 Posted March 16, 2019 This might be multi-stepped, but there is a way to do what you're wanting. It requires some arcing, mirroring and some rotation. I was able to do it in SBE, so if it can be done in that antiquated program, there must be a way to do it VM or other programs. I wrote the step I took in SBE, you might be able to recreate that in VM - type your text - mirror (veritcally) - invert it - arc it - swing it to the bottom (SBE gave me pull handles to do that) - mirror (vertically) voila! Quote Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 16, 2019 Whenever you arc text (follow around the circumference of a circle) it's always a good idea to KERN the text out. This way, you avoid the letters hitting each other (especially on the inside bottom of the arc). For the record, SBE offers arc text as a feature. Including the radius of the arc, above or below circle, clockwise or counterclockwise, and justification. (TEXT menu -- Text follow arc) This brings up a dialogue box with several options to configure the way it arcs. Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted March 16, 2019 After you arc the text, click on the text tools button at the top of the screen, then on the left, click on the Text on Arc tab and you have 3 options, above, above and below, or below. 1 Quote Share this post Link to post Share on other sites
Guest SCharlesworth Posted July 22, 2019 I have LTR but do not see the ARC tools, I guess I need to upgrade, AGAIN? Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 22, 2019 Sometimes just having an extra software that has other options helps. You can do ARC text in FREE Signblazer, and export it as an .eps file. Import into VM. Won't cost you a penny. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted July 22, 2019 3 hours ago, Guest SCharlesworth said: I have LTR but do not see the ARC tools, I guess I need to upgrade, AGAIN? You might look closer before giving up. The VM tech said it has it. Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted July 22, 2019 Inkscape can do it as well, although not as easily as Signblazer or VM. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted July 23, 2019 Arc text is in LTR as shown in the posts above. Quote Share this post Link to post Share on other sites
ParkersWWandDesign 0 Posted July 30, 2019 I see arc text in my version of LTR but the screenshots above do not look like my version. I can arc but I cannot “reverse” arc from the bottom. I do not have the “toggles” shown to do that. Quote Share this post Link to post Share on other sites
