Allan76 0 Posted May 16, 2016 Can anyone advise me of how to stop the tilte cutting when using a vinyl Cutter. I am able to cut text and then these tiles start cutting which is not required. Share this post Link to post Share on other sites
lizzylou 11 Posted May 16, 2016 Please show a screen shot of what you are referring to. Next to post button is more reply options, upload your screenshot. Which cutter,? How connected to what operating system.? You posted in Signblazer thread, is that the software? Share this post Link to post Share on other sites
pshawny 410 Posted May 16, 2016 Sounds like you are referring to weeding boxes. On the cut screen, right before you hit cut, you will see some cutting options to the left side of the screen. Uncheck everything that says "Weed". Weed All is usually selected by default. Play around with them to see what each one does. They do come in very handy. Share this post Link to post Share on other sites
arty-rc 719 Posted May 16, 2016 Check your "length" setting in the cutting setup window. Make sure it's set to longer than your graphic. Share this post Link to post Share on other sites
