storm2313 25 Posted May 14, 2016 I noticed if you adjust the contour cut perimeter to .004 to anywhere under .010 you never see the adjustment in the software reflected on the graphic your putting it around. I want to make sure even though the software isn't reflecting such small adjustments it will still be cut at the set perimeter be it .004, through .010, and so forth. I realize we're talking about thousandths of an inch, but I was under the assumption the software would reflect it regardless of how small an adjustment you make. Thank you for any input. Quote Share this post Link to post Share on other sites
signyouup 178 Posted May 14, 2016 Can you zoom way in and see if it changes? Quote Share this post Link to post Share on other sites
storm2313 25 Posted May 14, 2016 I honestly didn't try that till you mentioned it. It make sense that would make it identifiable, but it didn't make the line change. I did find if you zoom in that anything past .010 of an inch is visually reflected in the software. I hope Futurecorp confirms it isn't visual in the software, but the contour line will be adjusted to perimeter dimensions when performing the physical cut. Thank you for the excellent suggestion. Quote Share this post Link to post Share on other sites
signyouup 178 Posted May 14, 2016 You're welcome. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted May 16, 2016 Just try a couple small test cuts and check for yourself if the line moves. Seems like a pretty easy thing to check out. Quote Share this post Link to post Share on other sites
storm2313 25 Posted May 16, 2016 Honestly to visually see a few thousandths is really hard especially when we're looking at a variance of 2-3 of them. I was just curious if Futurecorp can confirm the software doesn't register those adjustments under .010 in down to .004. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted May 19, 2016 The software works down to very small increments but we must cap this to prevent processing errors between very large page sizes and large zoom levels (it is a range). The numbers mentioned here are very small and most cutters only work to 40 units per mm or 1000 units per inch. Quote Share this post Link to post Share on other sites
storm2313 25 Posted May 21, 2016 Makes sense. That's what I was thinking. Is there a certain measurement that's recommended to stay within? Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted May 21, 2016 It all depends on the artwork and size but 0.2mm or 0.008" is barely noticeable... Quote Share this post Link to post Share on other sites
storm2313 25 Posted May 21, 2016 Well said. I will stay within those limits. Thank you for your excellent support. Quote Share this post Link to post Share on other sites
