lesliel 0 Posted May 3, 2016 Hello, I just purchased the Corerldraw x8 and i'm having problems sending it to the cutter. any advise is appreciated. Share this post Link to post Share on other sites
MZ SKEETER 4,528 Posted May 3, 2016 Corel draw is not cutting software. It is design software, You must use a cutting software to send to your vinyl cutter.. If your cutter was purchased from UScutter then install the cutting software that came with it,, and drivers for your vinyl cutter. Send Corel draw vector to your cutting software, then cutting software to your cutter. Here is the set up instructions. http://www.uscuttersupport.com/laserpointII-vinylcutter-setup.html Share this post Link to post Share on other sites
lesliel 0 Posted May 3, 2016 I have the Laserpoint 2 and it came with Sure Cuts A Lot Pro. Share this post Link to post Share on other sites
MZ SKEETER 4,528 Posted May 3, 2016 Ok so what is wrong? I do believe that Sure Cuts A Lot has a plug in to send to Sure Cuts A Lot. Or you can probably import your designs into Sure Cuts A Lot. Craftedge.com does have their own forum. for SCALP http://www.craftedge.com/index.html 1 Share this post Link to post Share on other sites
Dakotagrafx 7,180 Posted May 3, 2016 then you would export your artwork out of corel into a file format that you could import into scalp so you can cut it - Share this post Link to post Share on other sites
gnizitigid 4 Posted May 3, 2016 Here are simple tutorials http://www.craftedge.com/tutorials/tutorials_scal4.php Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted June 10, 2016 Bet you were hoping you could do the Corel Draw to the cutting software right? I never did it heck I didnt even know you could do that with SCALP. I will stick with Cutting studio. Share this post Link to post Share on other sites
