top53
Anyone else having problems with Magnum Magnetic
Made 12 magnetic signs using Magnum Magnetic 10 have blown off. I rounded corners and vehicles were cleaned before installation.. They are 12 X 28 so I had to buy a roll and cut them to size.
Did you use the 25 mil or 30 mil? the 30 mil has more pull than the 25 mil magnetic material.
The 25 mil is not recommended by the manufacturer for vehicles.
I used the 25 mil because it came in 25 ft rolls the only way they sell the 30 mil is in 50 ft rolls, go figure and it had to be cut to 12 X 28
never had a problem with the 30 mil here
Hey!  Just curious, do you print directly on your mag material and then cut it, or print on vinyl and then mount on mag and trim it by hand?
Thanks.
with all the aluminum and composites in vehicles now you also have to check each one- magnet doesn't hold well to a compsite panel , aluminum or some allows they use to reduce weight
