shankun
Running in Parallels?
Put it simple, USB crapped out on my laptop.  Fired up my old laptop but have to close out and restart the cutter and program due to a sending but not cutting issue, pretty sure it has to do with the computer being about 3 million years old. Would love to use my MacBook Pro.  Running parallels I am running into a no internet, off line registration required.  Is this typical?  Went to the site listed on the bottom of the offline registration and says not found.  I have another computer I can use, just figured it would be easier to use my mac in parallels.  If this is a known issue and will not work I will dump this idea and not spend any more time than the 4 minutes I have so far.
Well, I was able to go to Safari put in the address, put in my info and serial number and computer ID, got my registration code.  Put it in and made a quick test cut.  So I would chock this up to a success.  I will update if I run into any issues.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
