MetalHeadGraphix 0 Posted April 22, 2016 I used to make vinyl decals and now I've got back into it. I normally use CorelDraw to do all my images but don't have it on my new computer. My USCutter came with VinylMaster Cut which I guess is the most basic version but here's my issue. I have a nice black/white image of a Boston Terrier and when I vector it, it looks perfect, but when I hit Trace, it inverts the image colors so all I get is the interior. Can't understand why it looks perfect then when you trace it it inverts it. Thanks. This is the image, when I hit Trace, all it gives me to cut is the white section not the black. Quote Share this post Link to post Share on other sites
VinylMaster 143 Posted April 22, 2016 Traces fine on our system. Do you mean in the Vectorizer or after you click Accept (after tracing)? What does it look like in Wireframe on a page in VinylMaster? Quote Share this post Link to post Share on other sites
MetalHeadGraphix 0 Posted April 22, 2016 After Tracing it gives me an inverted image. More weirdness, if I copy this from CorelDraw directly into VinylMaster it looks perfect, except it leaves out the word DRUNKS. Makes no sense everything else is there except for that word. I ordered all this equipment for a home based business and if that doesn't work I'm gonna be screwed. You can't cut directly from CorelDraw. Other things I've copied over from CorelDraw have worked perfectly. It's a common Arial font. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,487 Posted April 22, 2016 It would help if you would post up some screen shots of your computer while doing this.. Show your Vinyl Master work area...Show the steps you are using. Or even a video.. Quote Share this post Link to post Share on other sites
MetalHeadGraphix 0 Posted April 22, 2016 Okay here is two instances where I've copied and pasted CorelDraw images/text into VinylMaster. It just jumbles it up and butchers it. My VinylExpress software I got free with my other cutter wasn't this bad. I never had this issue. This makes it practically unusable unless i create what I need in Vinyl Master and with its limitations I don't see it working for me other than simple single layer designs. I can't take the time to figure out all my already existing designs each time I need one cut. Quote Share this post Link to post Share on other sites
skarekrow 1,840 Posted April 23, 2016 What format are you saving your raster/vector work in Corel that you are putting into Vm? Have you tried other formats? Are you converting your text to Paths? Quote Share this post Link to post Share on other sites
Coaster36 327 Posted April 23, 2016 Hes not saving. Hes coping and pasting the artwork. I noticed that vinylmaster doesnt like copy and paste from other programs. Signblazer didnt mind that but it doesnt work in vinylmaster. Your best bet is to save the file as an svg or eps. I think youll get better results with an svg format. Quote Share this post Link to post Share on other sites
MetalHeadGraphix 0 Posted April 24, 2016 Yeah they are just in CorelDraw format and I'm copy/pasting them over. Quote Share this post Link to post Share on other sites
H2Ohydrographics 25 Posted April 24, 2016 Yeah they are just in CorelDraw format and I'm copy/pasting them over. May not be explaining it correctly, but, after saving in Corel, can u export It as a bmp file, then in robo - import, get outline, paste and then cut? After you've done all the work in Corel, steps are fairly fast in basic cutting program? Hope u get in figured out... Quote Share this post Link to post Share on other sites
Guest Future Corporation Support Posted April 25, 2016 When you vectorize, you will notice the detected colors that will be traced at the bottom area of the vectorizing screen.The color that is detected as the "background" will have a red cross through it, indicating that it will be treated as the background color, and not traced.In your situation, try right clicking on these boxes, so that the black color does NOT have a red cross through it (it will be included in the trace), and the white color DOES have a red cross, indicating that white parts of the image will be treated as the background, and not traced. Quote Share this post Link to post Share on other sites
bigfrank 16 Posted August 5, 2016 On 4/21/2016 at 7:41 PM, MetalHeadGraphix said: I used to make vinyl decals and now I've got back into it. I normally use CorelDraw to do all my images but don't have it on my new computer. My USCutter came with VinylMaster Cut which I guess is the most basic version but here's my issue. I have a nice black/white image of a Boston Terrier and when I vector it, it looks perfect, but when I hit Trace, it inverts the image colors so all I get is the interior. Can't understand why it looks perfect then when you trace it it inverts it. Thanks. This is the image, when I hit Trace, all it gives me to cut is the white section not the black. I have vectorized and cut this exact image and it worked fine. Sounds like your copy/paste is making the problems. Quote Share this post Link to post Share on other sites
darcshadow 1,391 Posted August 5, 2016 I think there may be some terminology confusion as well. You say you vector it, and then trace it? If it's vectored there is no need to trace. Tracing is used to take a raster image and turn it into a vector image. Quote Share this post Link to post Share on other sites
tatinc2000 10 Posted August 5, 2016 Just import straight to VinylMaster and convert in there. I use CorelDraw X7 to VinylMaster or V-Carve Pro 8 to VinylMaster. Copy and paste does some weird stuff. Instead select all in Corel, Export as .eps from Corel, import to VinylMaster. Works great for me. I also noticed that VinylMaster doesn't do good with some .dxf files because it changes the image to short lines instead of curves. Quote Share this post Link to post Share on other sites
