wayneg 0 Posted April 21, 2016 How do I choose a specific Pantone in Flexi 10? There MUST be an easier way than to navigate through all the Pantones until I get to my needed Pantone number. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 21, 2016 So how are you doing it? It is all set up in categories with numbers in order...and there is only 11 categories on mine.. Flexi10 And you can eliminate some of those categories by the numbers.and Letters. Make your own little notes, what categories are for what .. Share this post Link to post Share on other sites
wayneg 0 Posted April 22, 2016 I tried doing it in "Color Spec." I can find my desired color, but it does not apply to object(s). Am I missing something here? The only way I can get an object to accept a color is to use the swatch book at bottom (row) and go through all the Pantones (which are sorted by color groups, not numbers), then pick my desired Pantone. Will "color spec" allow me to apply a Pantone to object(s)? Share this post Link to post Share on other sites
wayneg 0 Posted April 22, 2016 I'm using Flexi Pro v10.5 Share this post Link to post Share on other sites
wayneg 0 Posted April 22, 2016 I meant FlexiSIGN Pro 10.5 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 22, 2016 My software is the same as yours, just no cutter drivers......I don't know what you are doing.. Here I did an oval in a Pantone color of blue shows in stroke editor the color and number, After I add it to my swatch table at the bottom, All new colors have a small dot on them, because they have been added, and I can put my cursor over those color swatches and it shows me Pantone,, the number and vendor Pantone. I just checked my Flexistarter 8.6 and it is the same way.. Not all Pantone colors have numbers, some have color names. I only add 1 color at a time that I need to use... . Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 22, 2016 This is Flexistarter 8.6,, so years old.. and it does the same thing...and if you look at the bottom I had my cursor over the color swatch and it showed the vendor and color name.,as well as in the Fill/stroke editor. Share this post Link to post Share on other sites
wayneg 0 Posted April 22, 2016 Yes, this is understood. My issue is locating a particular Pantone. You have to scroll through the Pantone table to find that Pantone you need to use. In Corel, you just type in a Pantone number or colr and it instantly appears, so you can apply it to your object(s). Is there ANY WAY to quickly locate a Pantone that is not already in your personal or document palette? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 22, 2016 What about using FIND?? in the Color Palette It shows any color close in the Pantone library, when you check the Pantone folder. Softwares all have their differences and features for a reason. .. Share this post Link to post Share on other sites
wayneg 0 Posted April 25, 2016 Yes, I tried "find" in the "Color Specs" roll-up. It will find Pantones, but how the heck do you apply this Pantone you found to an object(s) without having to scroll through the Pantone pallette(s). Ridiculous - or am I missing something? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 25, 2016 Here is your tech support,. as well as they have a forum. esupport@thinksai.com Share this post Link to post Share on other sites
wayneg 0 Posted April 25, 2016 Thanks. I just emailed them. There has GOT to be a solution... Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 25, 2016 Thanks. I just emailed them. There has GOT to be a solution... Pretty sure they will need your Flexi license number,,before they will help... too much pirated Flexi software out there... My software is all registered on their site. So I just give my license # in the first email. Share this post Link to post Share on other sites
wayneg 0 Posted April 25, 2016 No problem getting an answer from them (I AM registered). Here is their response: "Unfortunately that is the only way to do it." ___ I'm bummed. There are over 1000 Pantones and they are sorted by color groups, not even sorted numerically. Share this post Link to post Share on other sites
wayneg 0 Posted April 26, 2016 Several of you are missing my point of this thread. Sure Flexi lists all the Pantones, but you still have to navigate through the library to get to the one you desire.Changing sort order to "name" is the best it is going to get in Flexi.In CorelDRAW, you simply double-click the fill icon, choose the "palette" tab (defaulting to Pantone solid coated), type in the desired Pantone number, and hit OK. Applies that specific Pantone to your object(s). Takes 1-2 seconds to find and apply a Pantone. Flexi (and Illustrator) definitely need to add this feature to their applications. It's back to Corel ("Illustrator on Steroids") for me...Thanks for trying, Everyone! Share this post Link to post Share on other sites
