elmeroperez 0 Posted April 14, 2016 Well, i recently purchased Make The Cut, which the plotter i have does support. its working, it does cut but the problem that i'm having is that whenever i send something to cut, it starts the line but then goes over to another corner or spot and starts doing jagz and zig zags , then it sometimes goes back to the work then stops. it doesn't even finish the cut. i guess it's the plotter,that since i didn't use it in quite some time, maybe the sensors are dirty or something. if anyone has or has had this same problem and knows the solution, please tell me what i can do to resolve it, attached i will leave one example of what i'm talking about. Thanks.. Share this post Link to post Share on other sites
darcshadow 1,626 Posted April 14, 2016 sounds like either static issues, or wrong driver. I don't have Make the Cut so can't help there. You could always download the free SignBlazer cut program, it works with the MH Series. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 14, 2016 Make sure the baud rate is set to 4800. That is the baud rate for MH MK2 Share this post Link to post Share on other sites
