storm2313 25 Posted April 5, 2016 I see in the Objects link on the toolbar you can add a weedbox, and it does put a box around the items I would like to have a weedbox. The issue is it doesn't cut the box out. My prints actually printed the box, but never cut around it. How do I add a weedbox, that's ready to be cut around the objects I select? Thank you all for your support. Quote Share this post Link to post Share on other sites
kbenz 0 Posted April 5, 2016 when you send it to cut. the box that pops up there is a box you can check. "auto weed box" Quote Share this post Link to post Share on other sites
storm2313 25 Posted April 6, 2016 I'm cutting graphics, and only use the contour cutting module. I don't have the option for "Auto Weed Box". Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted April 7, 2016 It depends which level and version of that level you have as to whether you will see a weedbox option - if you can see Advanced tools in the Contour Cutting Wizard and check this, then you will see the Weed Box option. If not, then the level/version you have doesn't have this tool. Quote Share this post Link to post Share on other sites
storm2313 25 Posted April 7, 2016 I have VM Pro, but I see under the objects tab to add a weedbox. I've done that, but it simply prints the weedbox without performing a contour cut around it. What am I missing? It's logic if the software has the feature it can be used, I think I'm missing a step. Please let me know. Thank you. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted April 8, 2016 Step 1. Add a weedbox from the Objects (menu) to the target object. Step 2. Select the Object (with the weedbox) and click Ungroup (first row of tools or from the Arrange menu). Step 3. Select the weedbox (not the Object) and click Contour Cut Color in the Color Bar (right side – icon is of a cutter blade). Step 4. Select the Object and the weedbox and click the Contour Cutting Wizard (first row of tools) Now the weedbox will load as a Cuttable curve object into the Contour Cutting Wizard. Tip: Create the contour cutline for the object using the Create Cut Contour module rather than the Contour Cutting Wizard to avoid mixing up the weedbox with the contour cutline. Quote Share this post Link to post Share on other sites
storm2313 25 Posted April 8, 2016 Thank you for your excellent support. Quote Share this post Link to post Share on other sites
