Macon Innovations 228 Posted March 30, 2016 I have Vinyl Master XPT 4.0 , How do i reset the program back to default settings? Im sure ive looked over it but i cant find it to save my life.... Thanks Quote Share this post Link to post Share on other sites
mb20music 760 Posted March 31, 2016 Maybe the only way to do it is to uninstall and reinstall the software, I could be wrong though. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted March 31, 2016 Download and unzip this file onto your Desktop: http://www.iifuture.net/downloads/DefaultSettings.zip Then from the Tools (menu) in VinylMaster click Settings. Next, from the File (menu) in Edit User Settings, click Load Settings then navigate to the unzipped file, select it and click Open. Quote Share this post Link to post Share on other sites
mr300s 1,272 Posted March 31, 2016 I love when folks from the signware join forces with us thank you !! I remember when Jerry (God rest his soul) started and invented Sign Blazer and was always on here helping everyone with small problems ... Quote Share this post Link to post Share on other sites
Macon Innovations 228 Posted March 31, 2016 Download and unzip this file onto your Desktop:http://www.iifuture.net/downloads/DefaultSettings.zip Then from the Tools (menu) in VinylMaster click Settings. Next, from the File (menu) in Edit User Settings, click Load Settings then navigate to the unzipped file, select it and click Open. Thank You Quote Share this post Link to post Share on other sites
Macon Innovations 228 Posted March 31, 2016 I love when folks from the signware join forces with us thank you !! I remember when Jerry (God rest his soul) started and invented Sign Blazer and was always on here helping everyone with small problems ... I couldn't agree more Quote Share this post Link to post Share on other sites
Macon Innovations 228 Posted April 1, 2016 I tried the reset and that did not fix my problem so i guess i still need help......When i try and cut vinyl now for some reason it cuts in the opposite direction that it shows on the screen......If i lay it out horizontal it cuts vertical and vice versa.......I though i some how messed up a setting but now i reset it to defaults and it is still doing it......Any help would be great..... Quote Share this post Link to post Share on other sites
Camel 7 Posted April 1, 2016 <blockquote class='ipsBlockquote'data-author="Macon Innovations" data-cid="415868" data-time="1459473456"><p> <br /> <p class='bbc_indent' style='margin-left: 40px;'>I tried the reset and that did not fix my problem so i guess i still need help......When i try and cut vinyl now for some reason it cuts in the opposite direction that it shows on the screen......If i lay it out horizontal it cuts</p> <p class='bbc_indent' style='margin-left: 40px;'>vertical and vice versa.......I though i some how messed up a setting but now i reset it to defaults and it is still doing it......Any help would be great.....</p></p></blockquote> When you're in the "vinyl spooler" , look up in the settings tab on the main menu, FILE - EDIT - CUTTER - SETTINGS.... So forth... Click onto "settings", scroll down and click "Change Rotation" , (very bottom). You'll receive NO confirmation, or see any indication this has been switched, but now your cutter will cut the way it is shown in the "preview" . This is NOT the same as "rotate" when you check the little box in the cutter preview screen. Note to VM, may be a toggle should be added there to show users this has been turned on or off. 1 Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted April 1, 2016 You can also set Rotate on most cutters. These types of questions are answered in the FAQ, please see: http://iifuture.net/faq/index.php?action=artikel&cat=53&id=195&artlang=en Quote Share this post Link to post Share on other sites
Macon Innovations 228 Posted April 2, 2016 Thanks Quote Share this post Link to post Share on other sites
Guest Bob Posted January 11, 2017 I have vinyl master on my laptop and computer. From the laptop it doesnt show all the fonts. What should I do? Quote Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 11, 2017 1 hour ago, Guest Bob said: I have vinyl master on my laptop and computer. From the laptop it doesnt show all the fonts. What should I do? each computer will only show the fonts loaded in the system folder on that computer - so if you download fonts on one computer your have to do the same for the other one 1 Quote Share this post Link to post Share on other sites
bikemike 711 Posted January 12, 2017 And installed. Just having them there will not work in most programs. 1 Quote Share this post Link to post Share on other sites
Harley 0 Posted October 30, 2018 Keep in mind that the more fonts you have installed (key word is "installed"), the longer it will take for any program that has a font menu to load. Lessons learned from the 20 minute boot up days. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted October 30, 2018 While it can take longer, it's not as bad as it use to be and you can have several hundred or even a thousand fonts before you start to notice a real speed impact. Quote Share this post Link to post Share on other sites
Guest Us cutter and sign master Posted November 16, 2022 My us cutter keeps cutting through my graphics, not just cutting the. Out. I can't figure out how to fix this. Any suggestions? Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted November 16, 2022 What software are you using, and have you registered it? Several cutting software tools will cut an X through a design if the software is not registered. Quote Share this post Link to post Share on other sites
