newtovinyl
Titan 2 loading material
I am very new to cutting vinyl.  I have had my Titan 2 for about a month now an so far I  haven't cut anything.  I am struggling with this.......almost wish I would have never gotten myself into this.  But I did.   When I load my HTV it scrunches up under the rollers.  Almost like the pressure isn't the same??  I have tried to adjust different things.  I totally do not know what I am doing.   Can someone kindly help me???
Are you making sure that the pinch rollers above are directly over the grit rollers below?  As they must be to operate correctly.. Can you take a photo from the front of the machine as to how you have it lined up?  That could help. ...
The same happens with regular vinyl.
I was not making sure the pinch rollers were over the grit rollers.   I will do that and see what happens.
Thanks bunches!
Yes, the pinch rollers must be directly over the grit rollers below, that is how your vinyl moves/feeds...
