blacklabelgraphix 3 Posted March 23, 2016 I may have over looked but I didn't see an answer anywhere. I have: Flexi 10 53" Titan 2 My question is in Flexi 10 Production Manager to setup this cutter what model do I choose under the Saga brand? The choices are: SAGA-1350I, 1350II, 1600I, 1600II, 2100I, 2100II, 2600I, 2600II, 360I, 360II, 550I, 550II, 720I & 720II. Any help would be much appreciated. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 23, 2016 I can't remember if it is the 720i or 720ii but think the first one - give it a shot Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 I called USCutter and they were no help. He said they only support Flexi 12. The only thing he could tell me was the Saga-1350 was a 53". I have the "Saga-1350II" as my cutter in Production Manager, when I go to cut something it shows "cutting" in production manager but the cuter does nothing. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 24, 2016 Try on this page of downloads. Look under SOFTWARE Look under FLEXI> SAGA(TITAN) FLEXI DRIVER PACK> Download and install http://www.uscuttersupport.com/downloads.php Make sure you follow all of the instructions from this page.. http://www.uscuttersupport.com/uscutter-titan-2-setup.php Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 Yes I went there. Under the "Cutters" column it doesn't have Titan or Saga. I did download the Software - Saga (Titan) Flexi Driver Pack. Which that added the list of Saga cutters to the Flexi Production Manager. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 dang I missed the part on the 53" - I should have said try the 1350I - but glad you got the driver pack installed so the problem is solved Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 No problem hasn't been solved. With the Saga-1350I and Saga-1350II, when I click cut nothing happens. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 24, 2016 Try a different USB port. or a different cable. Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 When the cutter is "online" and ready to cut what should be displayed on the screen on the cutter? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 have you been able to cut with any program with this cutter? If not did you install the windows driver for the cutter first? Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 I just bought this cutter used. When I'm using a printer/usb cord and I plug into laptop "Saga Cutter/Plotter" pops up under control panel/devices and printers. When I use a serial/usb cord "com8" pops up. In production manager I have Saga-1350 going to the com8. Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 Saga-1350I says "Cutting...0%" and stays like that. Saga-1350II says "Cutting" and goes away. Like it cut and is done. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 24, 2016 Here is the user manual and make sure the baud rate is set at 38400 http://www.sagacnc.us/download/saga-user-guide-15-09-20.pdf Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 http://www.uscuttersupport.com/uscutter-titan-2-setup.php Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 On that page when I go to install USB Drivers for Windows 7 and click install, "Add Printer Fail" pops up. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 On that page when I go to install USB Drivers for Windows 7 and click install, "Add Printer Fail" pops up. what version of windows are you running? - are you running the install as an administrator? Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 Windows 7 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 just tried it on my windows 7 professional 64 bit and installed ok from that link Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 I wish mine would. It doesn't matter what port I try a popup box says add printer fail. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 lets back up a bit - you say windows 7 but which one home 32 bithome 64 bit pro 32 bitpro 64 bitultimate Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 24, 2016 just tried it on my windows 7 professional 64 bit and installed ok from that link I also got ADD printer fail Windows 7 Home 64 bit. When you click INSTALL. I did everything right, extracted after downloading..Go to set up BOX choose the cutter, choose USB 001, click install. I also tried different cutters and Com port #s No go. 2 Share this post Link to post Share on other sites
blacklabelgraphix 3 Posted March 24, 2016 I'm using Windows 7 home premium, service pack 1, 64 bit Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 I've reached out to usc on this - hopefully they stop by - I would call support again and tell them of the driver fail Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 24, 2016 I just went to Cutterpros.com support and installed the driver there it installed just fine....They sell Sagas. And they have Flexi install instructions. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 24, 2016 I also got ADD printer fail Windows 7 Home 64 bit. When you click INSTALL. I did everything right, extracted after downloading..Go to set up BOX choose the cutter, choose USB 001, click install. I also tried different cutters and Com port #s No go. carolyn - did you try right clicking on the setup file and select run as administrator? Share this post Link to post Share on other sites
