Pierce8468
Do I have a bad Machine or is it just a bad machine?
I am not new to plotters,but new to the SC cutter.     I recently purchased one as a back up to replace my old MH cutter as my back up.  I wasn't expecting this thing to be a top of the line machine, but I did expect it to be better than my MH, but it certainly is not.    If I try to cut above 100ms the blade holder will stutter as it cuts.   even cutting as slow as 200ms it stutters.
well let's look over some things.  Are the white wheels of the carriage head firmly down in the track?.  and the carriage head can be moved back and forth nice and smooth?   Do you have the blade set correctly,  This is how. Below:  Is the blade holder firmly down in the carriage head.?    If you can provide a video, that would be great. Make sure the part that holds the blade holder isn't cracked or broken.
Make sure all the wheels to the carriage are in place, when mine arrived one had jumped out of the track caused me all sorts of trouble until I discovered it.
Does your cutter head move smoothly above 100mms and if so at what speed does it begin to stutter as it cuts
Have you ever contacted UScutter tech support on this?   If so,, what did they say?   If not, then contact them.
