Camel 7 Posted March 10, 2016 Anyone with this model know if this has a vacuum or suction hold down for the vinyl? Thanks! Share this post Link to post Share on other sites
mfatty500 454 Posted March 10, 2016 No that I know of, I have a CE 5000, and pull right off the roll Share this post Link to post Share on other sites
lizzylou 11 Posted March 10, 2016 They have a fan. The vinyl stays down just fine when cutting.with Graphtecs 1 Share this post Link to post Share on other sites
Camel 7 Posted March 10, 2016 Thanks for the quick replies. About to upgrade after 7 years. Excited and nervous. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted March 10, 2016 The Graphtec 6000-60 is a great cutter. I haven't had issues. for the price you cant go wrong. 1 Share this post Link to post Share on other sites
Camel 7 Posted March 10, 2016 We cut a lot of small detailed stuff, some letters are just 1/8" tall. We have Googled for a week for videos and cut samples but nothing shows the cut quality or detail. Also we sometimes have drop vinyl that's about 3" square, the way this machine seems to set itself up is by "seeing" the pinch rollers, can we still cut small sizes like this? Thanks so much gang! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 10, 2016 The pinch roller sensor can be disabled, I can put both pinch rollers on the large grit roller side by side and cut that small. 2" Great for detailed work. I turned my pinch roller sensor and media sensor off first day...Mine is the FC put can also be done on the CE6000 1 Share this post Link to post Share on other sites
Camel 7 Posted March 10, 2016 This is great to hear! So much information can be had in just a few minutes on the best vinyl forum around. :-D Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted March 10, 2016 And if you have scraps of vinyl you want to cut from get a cutting mat from a silhouette or use cheap poster board. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 10, 2016 And if you have scraps of vinyl you want to cut from get a cutting mat from a silhouette or use cheap poster board. Never had to... WHY? The cutter will hold 2" wide vinyl just fine...as long as you want it. I do it all the time.. Never use a cutting mat. Loosen the set screw in the back and slide the left pinch roller over on the long grit roller. You can put those pinch rollers side by side... Been doing it for years....If you look at the specs on that cutter the compatible media width is stated, 2"-28" 3 Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted March 10, 2016 Never had to... WHY? The cutter will hold 2" wide vinyl just fine...as long as you want it. I do it all the time.. Never use a cutting mat. Loosen the set screw in the back and slide the left pinch roller over on the long grit roller. You can put those pinch rollers side by side... Been doing it for years....If you look at the specs on that cutter the compatible media width is stated, 2"-28" That is true I have had issues on my end and I mean me not the cutter I just feel safer that way. Share this post Link to post Share on other sites
DCMoney 91 Posted March 10, 2016 We cut a lot of small detailed stuff, some letters are just 1/8" tall. We have Googled for a week for videos and cut samples but nothing shows the cut quality or detail. Also we sometimes have drop vinyl that's about 3" square, the way this machine seems to set itself up is by "seeing" the pinch rollers, can we still cut small sizes like this?Thanks so much gang! Did this with my CE6k-60, no issues doing small detail. 1 Share this post Link to post Share on other sites
mr300s 1,272 Posted March 10, 2016 Heat Vinyl is cheating LOL Done with my 5000 2 Share this post Link to post Share on other sites
Camel 7 Posted March 10, 2016 Thanks for those samples gang! Share this post Link to post Share on other sites
Camel 7 Posted March 12, 2016 Update, ordered the new graphtec ce6000-60 Thursday morning, will be here next Wednesday. We have always used serial connections with the older cutters because we had issues with USB, is serial preferred on this brand? I'd like to use it because I already have the cable and port on the pc. Now I have to fab a media basket! Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 12, 2016 Update, ordered the new graphtec ce6000-60 Thursday morning, will be here next Wednesday. We have always used serial connections with the older cutters because we had issues with USB, is serial preferred on this brand? I'd like to use it because I already have the cable and port on the pc.Now I have to fab a media basket! never had a problem with usb on a graphtec 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 12, 2016 No problems here with USB 1 Share this post Link to post Share on other sites
mr300s 1,272 Posted March 12, 2016 Had USB for years now no issues 1 Share this post Link to post Share on other sites
mfatty500 454 Posted March 12, 2016 Usb for me also, it probably will come with one. 1 Share this post Link to post Share on other sites
