jimm8dmt 0 Posted March 9, 2016 Hello, Sometimes the SC cuts the contour lines exactly as outlined in VinylMaster Cut, however, there are slight variations more often then not with certain corners being cut misaligned with the graphic. I've tried adjusting the pressure of my rollers and re-calibrating the machine. Also, I talked with US Cutter and they really dint have any advice other than what I previously mentioned. Also, I've cleaned the inside of the blade to ensure no materials have built up within the chamber. Do you happen to have any ideas for how I can get a consistent cut each time or is that asking for too much? Paying for a better machine sounds great, but just isn't an option for me right now. Thank you, Jimm Share this post Link to post Share on other sites
jimm8dmt 0 Posted March 11, 2016 I bought the tripp lite usb to serial adapter and re-ran the cuts - no dice. It is still not as consistent as it was before. =(((((( major bummer. This cutter is terrible. Share this post Link to post Share on other sites
